need help in figuring out what exactly do i need form hardwareperspective to make following setup:
Currently, I have:
4 Single LNB's pointing to 4 different satellites
1 4-Way Diseq splitter (Used as multiswitch in ProgDVB)
1 Coax cable
1 USB DvbSky receiver
All 4 satellites work OK and I'm happy with everything.
Now I need help to identify the hardware to extend this setup to TWO recievers over the same cable. I was looking everywhere but I cannot understand what hardware I need to make this happen. Only what i found was that is possible and than answers go on limitations that I am fully aware of. but no "How to" is to be found with 100% certanty it will work.
I do not care about the costs, just need to know the logic and what hardware I need to make this single cable distribution.
If anything, where should I post this question as I can't find a good Satellilte forum anywhere
Thanks!
