Hi!
I can't seem to find a option to stream unmodified TV channels.. I mean, I want to stream video without deinterlacing so I can perform better quality deinterlace clientside. Are the channels being transcoded too since there's deinterlacing happening? I can't switch it off!
Re: Prog Media Server raw
#2No any changes if video on server side. Current version not support transcoding...
#3Could you help me to get rid of the deinterlacing then? When the stream is opened in VLC, it is shown 25 frames per second. I think it should be 50 frames per second interlaced. Is renderer affecting it? Display driver settings? Decoder settings?
#4May be this is logic of VLC. You can record file and open and some editor or analyze software.
