hi all, it's my first post here
i have a problem: ProgDVB doesn't recognize plugin i copied to '.../progdvb/plugins/' - it just doesn't see it.
i use windows 7 x64 (skystar2)
i have tried few methods:
- u used progdvb in version 6.11.7 x86/x64
- i copied plugin files directly to progdvb folder, to plugins folder and also to every plugins/pipxx folders
- i installed progdvb also on non-system partition (unprotected)
- i started progdvb with administrator privileges and with windows xp sp2/sp3 compatibility
nothing helped me
ps
same plugin files work with another dvb applications
...so now please let our readers know about what you did...
if i would know ...
made few experiments with other dvb applications, older versions etc.
after that i tried to install progdvb one more time and it works now ... just like that
unfortunately, I am facing the same problem with the WinCSC plug-in as it disappeared when I did update to latest version, any ideas?!
