This card is running well with the original software WinTV2000.
It doesn't work with ProgDVB.
I can't choose a device from the list except "KWorld DVB" and "TS-Reader" and a third device which doesn't work.
The Drivers for my Hauppauge-card are new from 2006, October.
What can I do to use ProgDVB with the Nova SE2 ?
this is a card that runs on bda driver ...as others cards running on bda drivers too ....choose the DVB-S bda device in progdvb device list...
If there is no such device in the list...exit progdvb ...
then save this :
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Tuning Spaces]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Tuning Spaces\1]
@="{B64016F3-C9A2-4066-96F0-BD9563314726}"
"Name"="TT-DVB-S"
"Description"="DVB-S"
"Network Type"="{FA4B375A-45B4-4D45-8440-263957B11623}"
"Frequency Mapping"="ex:2d,00,31,0"
"System Type"=dword:00000002
"Network ID"=dword:ffffffff
"High Oscillator Frequency"=dword:00a1be40
"Low Oscillator Frequency"=dword:0094c5f0
"LNB Switch Frequency"=dword:00b28720
"Input Range"="ex:2d,00,31,0"
"Spectral Inversion"=dword:00000002
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Tuning Spaces\1\Default Locator]
@="{1DF7D126-4050-47F0-A7CF-4C4CA9241333}"
"Frequency"=dword:00b7e238
"InnerFECMethod"=dword:ffffffff
"InnerFECRate"=dword:ffffffff
"OuterFECMethod"=dword:ffffffff
"OuterFECRate"=dword:ffffffff
"ModulationType"=dword:00000014
"SymbolRate"=dword:00006b6c
"Polarisation"=dword:00000002
"OrbitalPosition"=dword:00000000
"Azimuth"=dword:ffffffff
"Elevation"=dword:ffffffff
"WestPosition"=dword:00000000
as xyz.reg...double click to import into windows registry and try again in progdvb...if this don´t work you are out of luck with this card in progdvb...
then save this :
"Name"="TT-DVB-S"
No Channel found
#3Thank you very much @SiLencer, you're great.
Now I'm able to choose the right device and I can add a LNB in the DiSEq-Menue.
Unfurnately no Channel was found at the search.
Can you help me again ?
try this (channellist astra 19.2) : http://www.zshare.net/download/channels-rar-f50.html
copy the files into : \progdvb\channels
hi i have similar problem with the new version with the some dvbs card.
i used the version 4.80.3 and it works fine but when i update to the 4.81 it can not start the bda driver.
i have tried your reg code from above but it does not work (the old version does also not work, but i was so wise to backup the old reg entries).
Now there are Channels, but no pictures
#8Thank you again, @SiLencer !
Now I have a lot of Channels but I can't watch TV, only black screen.
No idea what's wrong. Could there be a problem with DiSeq ?
It works with the Original Software from Hauppauge (Win2000).
But ProgDVB would be much better.
register Elecard codec : go in \progdvb\filters and doubleclick the ´register.bat´ file...
or try other codecs : viewtopic.php?t=604
this is all that can be done ....
still black screen
#10what a pitty, it still doesn't work.
So I must use WinTV2000.
Anyway - have lot of thanks, @SiLencer
And have a good time
what must i do after i copied the astra channel list in the channel directory ? yesterday with the older version it did not help. i had copied the channel list and then a have started a new channel search but progdvb only searched for 57 channels but noch the premiere channels !?
alternative Program
#12Edit by SiLencer : Viewing Pay TV without valid subscription is illegal!
Next time you will be banned....
viewtopic.php?t=9
closed
viewtopic.php?t=9
closed
