#1351
Hi Prog, the problem is when i change the Audio stream (language of channel) video will stop and the only way to watch channel is to reopen it, every time on every channel if i change Audio (right click on video) i should reopen or change channel. after reopening will play with new selected Audio with no problem ...
thanks
#1353
Prog wrote:Please send me ProgDVBEngine.log
here you go.
opened progdvb selected Discovery+1 changed audio to Italian , channel(video & audio & timeshift) stoped. (timeshift and the play/pause button are disabled)
didn't change channel or close progdvb, this is the ProgDVBEngine.zip
i think the problem showing here in the log:
21:53:31.644 - OSDManager::Window_Show
21:53:31.654 - OSDManager::Window_SetBitmap 386x54 rendering in 004ms
21:53:32.617 - * s:49 q:48 tr=339716 (0)
21:53:32.753 - c:key 1
21:53:32.850 - * s:49 q:48 tr=0 (0)
21:53:33.579 - ChannelGraph5::SetChannelSubStream 4
21:53:33.579 - Graph::Stop
21:53:33.580 - Th Exit Prog Audio renderer thread
21:53:33.601 - TimeShift::Cursor PushMode 1 1 (1937)
21:53:33.601 - ReaderCursor::SetPosition 1984340 (w=2880536)
21:53:33.601 - Prereader::EnablePushModeAndStartPlayback 1
21:53:33.602 - PreScanner::ParseAudioPid
21:53:33.630 - * s:49 q:49 tr=462292 (0)
21:53:34.644 - OSDManager::Window_Show
21:53:34.646 - OSDManager::Window_Delete
21:53:34.650 - * s:49 q:49 tr=490680 (0)
21:53:35.658 - * s:49 q:48 tr=465488 (0)
ProgDVBEngine.zip
Log
(4.96 KiB) Downloaded 377 times
#1354
a crash occurred and engine restarted , here is the ProgDVBEngine.log:
19:01:03.394 - c:key 1
19:01:03.806 - * s:43 q:46 tr=283880 (0)
19:01:04.820 - * s:43 q:47 tr=655368 (0)
19:01:05.837 - * s:43 q:46 tr=579980 (0)
19:01:05.880 - * s:43 q:46 tr=0 (0)
19:01:06.850 - * s:43 q:46 tr=517752 (0)
19:01:07.863 - * s:43 q:46 tr=380700 (0)
19:01:08.876 - * s:43 q:46 tr=497260 (0)
19:01:09.891 - * s:43 q:47 tr=551404 (0)
19:01:10.904 - * s:43 q:46 tr=625664 (0)
19:01:10.951 - * s:43 q:46 tr=0 (0)
19:01:11.919 - * s:43 q:46 tr=690900 (0)
19:01:12.933 - * s:43 q:46 tr=555164 (0)
19:01:13.413 - c:key 0
19:01:13.947 - * s:43 q:46 tr=510420 (0)
19:01:14.960 - * s:43 q:46 tr=463420 (0)
19:01:15.974 - * s:43 q:47 tr=414164 (0)
19:01:16.020 - * s:43 q:47 tr=0 (0)
19:01:16.988 - * s:43 q:46 tr=266208 (0)
19:01:18.001 - * s:43 q:46 tr=301740 (0)
19:01:19.015 - * s:43 q:46 tr=294784 (0)
19:01:20.030 - * s:43 q:46 tr=306252 (0)
19:01:21.044 - * s:43 q:46 tr=289708 (0)
19:01:21.090 - * s:43 q:46 tr=0 (0)
19:01:22.058 - * s:43 q:46 tr=409652 (0)
19:01:34.404 - Cache overload (Incoming Stream Cache -5120000) !!!
19:01:34.414 - Cache overload (Incoming Stream Cache -5120000) !!!
19:01:34.425 - Cache overload (Incoming Stream Cache -5120000) !!!
19:01:34.435 - Cache overload (Incoming Stream Cache -5120000) !!!
19:01:34.445 - Cache overload (Incoming Stream Cache -5120000) !!!
19:01:34.455 - Cache overload (Incoming Stream Cache -5120000) !!!
19:01:34.465 - Cache overload (Incoming Stream Cache -5120000) !!!
19:01:34.474 - Cache overload (Incoming Stream Cache -5120000) !!!
19:01:34.484 - Cache overload (Incoming Stream Cache -5120000) !!!
19:01:34.495 - Cache overload (Incoming Stream Cache -5120000) !!!
And more more more
what is "Cache overload (Incoming Stream Cache -5120000)" ?
ProgDVBEngine.zip
(174.49 KiB) Downloaded 358 times
#1356
Prog wrote:That mean some process crash and block input thread. Try without plugin.
i only use Hadu.dll plugin for CCCam card sharing to opening channels, i really need it. and hadu.dll haven't problem with other players.
#1361
I'm not sure but I think after update ProgDVB6.95.2Pro --> ProgDVB6.95.3Pro, ProgTV has started to crash randomly. It just closes the application.
Log file (attached) mostly shows:
22:30:35.950 - thread: 0x47c Prog TS demux reader thread
22:30:35.951 - !! TopLevelExceptionFilter !! ACCESS_VIOLATION/Continuable
Now I went back to ProgDVB6.95.2Pro just to confirm it.
EDIT: It wasn't problem of the new version.
I was a problem with video render. Switched from "Enhanced" to "EVR" and it's OK again.
ProgDVBEngine.zip
(90.52 KiB) Downloaded 384 times
#1362
ProgDVB Pro 6.95.4
Diseqc 1.1 doesn't work (or stopped working, I can not tell) with my TechnoTrend S2-3200 card.
Computer restart and power down/restart doesn't bring anything. Only channels on the default or last active input are visible.
Reverting to 6.95.3 solves the program (no configuration changed in between...).
The mentioned audio channel on the fly switching issue needing to reopen the channel persists in this version, also.
Marius.
ProgDVB Pro, registered, of course.
#1365
CAM module for Avermedia does not seem to work anymore.
With 6.94.4 it works. Verified also with Avermedia center - CAM module works properly there.
Recently I upgraded progdvb to 6.95.4. Since then it returns only "Empty slot". Its x32 version.
Avermedia Trinity A707 DVB-T/DVB-S with SatGate
