Re: ProgDvb Engine error problem
#19Do you get any error messages? If yes, post it's content in full here.
Try to start ProgDVB in debug mode (command line argument /debug can be edited into a desktop icon's props), and look through the protocols.
#20Remove this plugin.ahmedghazi wrote:So what is the solution !!!
#21Like i said my system stop working when i used the software !!!!Juergen wrote:Do you get any error messages? If yes, post it's content in full here.
#22I cant remove it because i am using microbox dongle device. any way ProgDVB6.63.2Pro work fine with my system and my device.Prog wrote:Remove this plugin.ahmedghazi wrote:So what is the solution !!!
#24I need this plugin to open scrambled channels by using microbox dongle device. like this......
#27In the other the section of options menu there is a part Called (use only one CPU) don't use it.
