Re: ProgDvb Engine error problem
still ProgDVB6.63.8Pro has engine error problem !!!!!!!!!
at ProgDvbNet.AudioVideoSettingsForm.()
at ProgDvbNet.AudioVideoSettingsForm.(Object , EventArgs )
at System.Windows.Forms.Form.OnShown(EventArgs e)
at System.Windows.Forms.Form.CallShownEvent()
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5444 (Win7SP1GDR.050727-5400)
ProgDvbNet
Assembly Version: 6.63.8.0
Win32 Version: 6.63.8
CodeBase: file:///C:/Program%20Files%20(x86)/ProgDVB/ProgDvbNet.exe
EngineApiWrapper
Assembly Version: 1.4.3.0
Win32 Version:
CodeBase: file:///C:/Program%20Files%20(x86)/ProgDVB/EngineApiWrapper.DLL
msvcm90
Assembly Version: 9.0.30729.6161
Win32 Version: 9.00.30729.6161
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57/msvcm90.dll
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
System
System.Drawing
ProgDvbNet.bc
Assembly Version: 1.1.2.0
Win32 Version: 1.1.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/ProgDVB/ProgDvbNet.bc.DLL
IPDev.Skins
Assembly Version: 1.3.21.0
Win32 Version: 1.3.21.0
CodeBase: file:///C:/Program%20Files%20(x86)/ProgDVB/IPDev.Skins.DLL
ProgDvbNet.CD
Assembly Version: 1.0.2.0
Win32 Version: 1.0.2.0
CodeBase: file:///C:/Program%20Files%20(x86)/ProgDVB/ProgDvbNet.CD.DLL
Accessibility
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
System.Design
System.Xml
ProgDvbNet.Win
Assembly Version: 1.0.1.0
Win32 Version:
CodeBase: file:///C:/Program%20Files%20(x86)/ProgDVB/ProgDvbNet.Win.DLL
enabled.
For example:
<configuration>
</configuration>
