T2 hd channels have no sound and scrambled program info
  • 1
  • 2
Re: T2 hd channels have no sound and scrambled program info
#16 by Prog
Please try again select divx. Also try change audio renderer for divx.
audio codec not depended from PC. If working on my PC then must work on your (on same channel)
  • Fri Jun 29, 2012 3:54 pm
Salych
Salych
Sun Oct 03, 2010 1:43 pm
#17 by Salych
The latest version of ac3filter supports aac decoding. Try it.
Windows 8.1 x64, Tevii S-470
  • Fri Jun 29, 2012 5:13 pm
CommanderLake
CommanderLake
Fri Jun 22, 2012 9:54 pm
#18 by CommanderLake
I cant find any x64 HE-AAC decoders and x86 progdvb wont work with my tuner and x64 progdvb has another problem when AC3 is available it still says its AAC.
  • Tue Jul 03, 2012 11:34 pm
#19 by Prog
I am recommend try to fix ProgDVB x32... What message you have?
  • Wed Jul 04, 2012 9:17 am
CommanderLake
CommanderLake
#20 by CommanderLake
No error messages it just cant change the frequency the tuners are set to so it only gets the channels for the last frequency the tuner was using then when I scan another frequency it returns the channels on the last frequency.
It seems like the 32bit software has trouble interfacing with the hardware on a 64bit os.
  • Wed Jul 04, 2012 10:32 am
#21 by Prog
No. Lot of users have x64 and my main PC is x64. It is not problem.
But every DVB driver have self specific. You can try change Settings->Device options.
  • Wed Jul 04, 2012 12:53 pm
CommanderLake
CommanderLake
#22 by CommanderLake
I figured it out I just unchecked Use ITunerRequest and it works!
Theres another problem, the EVR renderer wont work.
  • Wed Jul 04, 2012 1:36 pm
#23 by Prog
This render request .net 3.x and modern video card.
  • Wed Jul 04, 2012 1:51 pm
CommanderLake
CommanderLake
#24 by CommanderLake
I have .net 4 on windows 7 x64 and an nvidia GTX580, everything else works with EVR.
EVR works on the x64 version but not x86.
  • Wed Jul 04, 2012 2:02 pm
Yuri
Yuri
Fri Nov 26, 2010 5:56 pm
#25 by Yuri
.net 4 not including .net 2.0-3.5. So you have to install it too.
  • Wed Jul 04, 2012 4:41 pm
CommanderLake
CommanderLake
#26 by CommanderLake
7 has all .net versions by default up to 3.5.
  • Thu Jul 05, 2012 4:23 am
#27 by Prog
Do you have problem with both EVR modes? Not custom EVR good working on most PC. I am not know problems with it.
  • Thu Jul 05, 2012 5:05 am
CommanderLake
CommanderLake
#28 by CommanderLake
EVR has always worked just fine, maybe you should include the exception message in the message box that says "This renderer not supported. Changed to VMR", it should say "This renderer is not supported" by the way.
  • Thu Jul 05, 2012 5:13 am
#29 by Prog
ProgDVB have 2 EVR mode. Custom and usual. Custom can not working on some PC (depended from video driver) "usual" always working if OS support EVR. It is very simple and standard function.
ps: Try change video codec also.
  • Thu Jul 05, 2012 5:31 am
CommanderLake
CommanderLake
#30 by CommanderLake
Both custom and normal EVR will not work and I have tried several 264 decoders.
It seems I do have a problem with the 32bit EVR.
  • Thu Jul 05, 2012 5:50 am
  • 1
  • 2
  • It is currently Mon Aug 24, 2026 11:21 pm
