Big problem with Prog Media Server
  • 1
  • 2
  • 3
Re: Big problem with Prog Media Server
#16 by Prog
Please send me log from modern version.
  • Thu Apr 11, 2013 5:26 pm
momchil
momchil
Tue Aug 14, 2012 6:27 am
#17 by momchil
"modern version"?!
This is logs from 6.92.4, you wish from 6.92.6?
  • Thu Apr 11, 2013 8:05 pm
#18 by Prog
Yes. Do you use free version of server?
  • Fri Apr 12, 2013 4:22 am
momchil
momchil
#19 by momchil
This is new logs from server and cient. ProgDVB 6.92.6 Standart.
PMS Home - Unicast.
The speed is only 150-160KB/s. :(
Logs-client.zip
(1.79 KiB) Downloaded 265 times
Logs-server.zip
(10.77 KiB) Downloaded 259 times
  • Fri Apr 12, 2013 11:11 am
momchil
momchil
#20 by momchil
Prog?
  • Mon Apr 15, 2013 9:22 am
#21 by Prog
Log looks good. try change packet size of server side.
ps: What real speed of network when you copy of file?
  • Mon Apr 15, 2013 3:45 pm
momchil
momchil
#22 by momchil
Prog wrote: ps: What real speed of network when you copy of file?
Up to 100mbps. :)
I don't have this problem with 6.92.4, but with them I have other problem.
  • Mon Apr 15, 2013 9:27 pm
momchil
momchil
#23 by momchil
I have very big problem with ProgDVB 6.92.6(or 6.92.4) + stability mode and PMS Pro 4.01.
The program always freezing in start. :(
More in PMS Pro 4.01 I don't change UNICAST mode to Multicast and Broadcast because this field is disabled.
For me 6.92.4 with old PMS is best solution for instant.
  • Tue Apr 16, 2013 9:40 am
#24 by Prog
Why you need multicast in this mode?
  • Tue Apr 16, 2013 10:17 am
momchil
momchil
#25 by momchil
Just for testing. But this mode not work for me with PMS Pro 4.01. :(
  • Tue Apr 16, 2013 12:03 pm
#26 by Prog
I am not sure about multicast in this this mode. No one reason for this. Multicast good for IPTV.
  • Tue Apr 16, 2013 12:23 pm
#27 by Prog
Do you test multicast and tcp in old version? may be some problem with multicast in your network hardware?
  • Tue Apr 16, 2013 12:24 pm
momchil
momchil
#28 by momchil
Unicast work perfectly with PMS 3.71 except problem in this topic.
Multicast work perfectly with PMS Pro 3.71, but the traffic is always and this is as flood for the network.
  • Tue Apr 16, 2013 7:45 pm
#29 by Prog
Do you try change packet size on server?
ps: Then multicast not need for you also :)
  • Wed Apr 17, 2013 5:13 am
momchil
momchil
#30 by momchil
Yes, I changed packed size from 1400 to 7400 but without success. :(
I know for multicast, but just for testing. :)
  • Wed Apr 17, 2013 9:24 am
  • 1
  • 2
  • 3
  • It is currently Mon Aug 24, 2026 5:25 pm
