Big problem with Prog Media Server
Hi! :)
My english is very bad. Sorry!
I have very big problem with Prog Media Server(home).
Computer(Server): Windows 7 Home Premium x64 - ProgDVB 6.86.4 Standart x64 + Prog Media Server(home) 3.69
Conputer(Client): Windows 7 Home Premium x64 - ProgDVB 6.86.4 Standart x64 + Prog Media Client 3.40
Firewall(server & client) is OK.
Server protocol - unicast.
All work perfectly.
I can change channels on the server and all work without problem.
But after changes 2-3-5 channels and close the client, and again... and again(3-5-7 times, allways is differently) I lost picture(TV signal) on client side and ports on server is(look Control, this is flood from client!):
If click on APPLY button(without any changes) on PMS - all working again.
If change port on client side from 10999 to 11000 its work again, but client can't change channel.
If restart ProgDVB(server side) - all work again.
If block incoming port 11000 on server computer - all working again, but can't change channel.
TCP connections on server side(only ProgDVBEngineRun):
This is TCP flood from client to server. If close ProgDVB(client) the flood stops. If block all out TCP connections for ProgDVB(client) - the flood stops.
Please, help me.
Re: Big problem with Prog Media Server
Logs...
How I make this: Open client and change 3-4 channels. Close client. Open client again and change 3-4 channels. Close client. I make this 3-4-5 times and voila. I think this is server side problem because if I click on APPLY button into server window the server work again without problem.
P.S.: With new version(client and server) I have problem, because server streaming only ~150KB/s always(normally 500-700KB/s).
Logs-server.zip
(58.48 KiB) Downloaded 304 times
Logs-client.zip
(6.79 KiB) Downloaded 300 times
