Changed processor to 3.4 [ with slight overclock to 3.6 ] which must be enough for this kind of satcard.
technisat / technotrend hd.
When i start up progdvb hd runs fine for about 5 seconds after then cpu runs higher and higher till 100% cpu load and doesn,t come under 100 % anymore.
After restart of prog the same: about 5 seconds higher and higher cpu...
Sd runs fine, also shutting off computer with proglauncher running, computer takes very long time to shut down, this starts automatically with windows startup and i can,t disable it.
However with the original technisat viewer software hd runs with high cpu 35 - 100 % load but no freezes and useble picture is just fine.
Re: freezes hd channels sd channels ok
#17wrong wrong wrong.
arcsoft video and audio decoder. and use vmr-7+graphic card with dxva thats all.
Anixe HD in my piv 3,4 northwood.+ his 4670 agp=25% cpu usage +-
Take in mind winxp only works with dxva 1.0.....
winxp,pctv 310i analog,fm,DVB-T,skystar HD2 + CI dvb-s2
