Goodevening,
Installed prog version 6.61.1 pro on my xp pentium 4 system, but on the hd channels i get freezes and black screen, on the sd channels all seems ok.
using ffdshow for codec maybe other is better or fixing this problem.
Maybe someone can help
Re: freezes hd channels sd channels ok
#2Please send me ProgDVBEngine.log after this. (Settings->Options->Debug->Enable logs)
#3goodevening,
Hereby my log:
Hd freezes Sd channels ok, with Hd high cpu, also tryed other version of Prog,
and stability mode,
Regards
Hereby my log:
and stability mode,
Regards
- log.rar
- (148.15 KiB) Downloaded 437 times
#4Video codec for h264 and audio for ac3 not selected. Settings->Options->Video->Codecs
#5Thanks for your answer, have installed as described but still some freezes on hd channels,
Think i have to upgrade my videocard as it is under 512 Mb, [ if i have a look for the minimum requirements for Progdvb ]
Will post when i have installed it...
#6Please send me logs after codecs installed. In last time problem in ProgDVB settings (not in video card!)
#7Codecs installed, hereby log:
But also upgrade my videocard to 1 Gb,
Tnx.
Tnx.
- Log Progdvb.rar
- (91.98 KiB) Downloaded 430 times
#8DXVA or CUDA must be on.maxwin wrote: Hd freezes Sd channels ok
Regards
#9Goodafternoon,
I changed to dvxa in ffd show, still freezes and blocks, also did not upgrade my videocard at the moment.
Maybe someone can have a look whats wrong,
Tnx.
Tnx.
#10Check File->Input traffic->Packet lost. and what CPU load?
#11please test check on dxva in the File->DirectSh->Video decoder H.264/AVC->Properties with Cyberlink video codec.maxwin wrote: I changed to dvxa in ffd show
#12Upgraded videocard to 1Gb still the same problem freezes and blocks on hd / sd still ok.
Also tryed other codec pack but no solution aswell, still high 50 - 100 % cpu load on hd +/- 35 % on sd channels.
Also very long [ about 10 - 15 seconds zap time ]
Hereby new log:
Hereby new log:
- Logs.rar
- (240.02 KiB) Downloaded 385 times
#13it is not a video codecmaxwin wrote:tryed other codec pack
Use DXVA/CUDA (or change comp for more powermaxwin wrote:still high 50 - 100 %
#14Try last version of ProgDVB. Looks like some problem with input traffic (signal too low?)
#15Ok, thanks for al the help, tryed also with the original [technotrend viewer ] still the same problem.
So i will try other [dual core] instead of pentium 4 3.2 ghz system, think processor power is on the low side.
Will post results here...
