No channel info in ProgTV
  • 1
  • 2
User avatar
cynik909
Sat Jun 27, 2009 9:54 am
Re: No channel info in ProgTV
#16 by cynik909
Not fixed in 7.01.1 :(
  • Sun Jan 26, 2014 12:04 pm
User avatar
cynik909
#17 by cynik909
No changes in ProgDVB7.02.1Pro :(
  • Sun Feb 09, 2014 10:51 am
User avatar
cynik909
#18 by cynik909
v7.02.3 - still not fixed
Prog, is there any way to "manually" update epg database?
Maybe some cmd line which I could put to Windows start-up?
  • Sun Feb 23, 2014 8:42 pm
#19 by Prog
Hello. Sorry, I am busy in other part of application and not have time for this.
manual update of epg only in UI. What you like do with cmd? Start by scheduler?
  • Mon Feb 24, 2014 5:06 am
User avatar
cynik909
#20 by cynik909
OK, I understand you.
But if you could give some workaround it will be great because I can't update to any version 7....
If some command line could update EPG I could lunch it with Task Scheduler or simply with every computer startup.
  • Mon Feb 24, 2014 6:44 pm
#21 by Prog
But do you like start GUI interface of ProgDVB in scheduler? I think that is not good idea.
  • Tue Feb 25, 2014 5:57 am
User avatar
cynik909
#22 by cynik909
I don't want to lunch "full" ProgDVB. I wanted schedule something like "ProgDVB.exe /epgupdate".
Only some switch just to no lunch GUI.
I know that this option doesn't exist right now, but It was only an idea ;)
  • Tue Feb 25, 2014 7:47 am
vitajz
vitajz
Tue Jan 20, 2015 3:40 pm
#23 by vitajz
I had the same problem. Try enabling timeshift. It worked for me.
  • Tue Jan 20, 2015 3:43 pm
User avatar
cynik909
#24 by cynik909
Wow! I have no idea how did you figure out this... But it works! :D
Now I have just the last problem with ProgTV... When I press [OK/Channel list] button I have this strange screen:
Did you see it before?
Many thanks!!
  • Thu Jan 22, 2015 7:36 pm
#25 by Prog
Is it depended from Video renderer? I am not have this problem.
  • Fri Jan 23, 2015 6:34 am
User avatar
cynik909
#26 by cynik909
I use "Enhanced Video Render". After change to "EVR Custom Presenter" or "VMR-9 Renderless" no change :(
  • Sun Jan 25, 2015 3:37 pm
#27 by Prog
Do you use right menu?
  • Mon Jan 26, 2015 9:09 am
User avatar
cynik909
#28 by cynik909
No.
I've tried to switch it in the settings but this black space appears always on the right side.
  • Sat Jan 31, 2015 4:28 pm
  • 1
  • 2
  • It is currently Mon Aug 24, 2026 12:41 pm
