Lifeview FlyTV Express X1MST-STA2,PD no tuning on ASTRA19.2E
  • 1
  • 2
mittolo
mittolo
Sun Mar 30, 2014 12:14 am
Re: Lifeview FlyTV Express X1MST-STA2,PD no tuning on ASTRA1
#16 by mittolo
Is this setting available in the Standard version of ProgDVB? As I said I installed the Standard version of the program and I can see only [Add Switch] and [DiSEqC] which are available only in the Pro version. I can't find [Diseq switch]->LNB1 & LNB2.
Should I install the Professional version for that?
  • Tue Apr 01, 2014 7:21 am
mittolo
mittolo
#17 by mittolo
Clean installation of ProgDVB Professional version with only ASTRA 19.2. :?
  • Tue Apr 01, 2014 9:30 am
#18 by Prog
No. Only pro version support diseqc. You can try trial version 21 days.
  • Tue Apr 01, 2014 9:41 am
mittolo
mittolo
#19 by mittolo
Yes I installed the pro version but as I said in my previous post and You can see the screen that I attached, it is still not working even with only ASTRA 19.2 sarellite.
  • Tue Apr 01, 2014 10:28 am
#20 by Prog
You must setup diseqc switch in TV Sources.
  • Tue Apr 01, 2014 11:37 am
mittolo
mittolo
#21 by mittolo
:? :( :cry: I can't test anymore. It says invalid or expired license :?: :?:.
I installed the standard ver. on 21/03 and pro version today :!: :!:.
There must be something wrong :!: :?: :!:
  • Tue Apr 01, 2014 2:09 pm
#22 by Prog
You can take addition 7 days trial key over web form
http://reg2.progdvb.com/index.php?modul ... wtrialform
  • Tue Apr 01, 2014 4:10 pm
mittolo
mittolo
#23 by mittolo
Thanks for the 7 day addition.
About diseqc, isn't there a 2.0 diseqc setting?
Still no tuning on ASTRA.
  • Wed Apr 02, 2014 3:10 pm
#24 by Prog
Try select 1.0 mode.
  • Wed Apr 02, 2014 3:13 pm
mittolo
mittolo
#25 by mittolo
I don't understand why som attachements disappear.
  • Wed Apr 02, 2014 3:26 pm
#26 by Prog
Where screen of TV sources?
  • Wed Apr 02, 2014 3:46 pm
mittolo
mittolo
#27 by mittolo
Is this configuration correct?
By the way my DiSEqc is 2.0 as can be seen in one of the previous screens
  • Wed Apr 02, 2014 7:03 pm
#28 by Prog
Correct. Now you can try look good mode in Settings->Device options.
  • Thu Apr 03, 2014 3:36 am
mittolo
mittolo
#29 by mittolo
Does ProgDVB Pro support switch DiSEcq 2.0? :?
  • Mon Apr 28, 2014 11:49 am
#30 by Prog
Yes, ProgDVB support diseqc switch more then 10 years :)
  • Mon Apr 28, 2014 12:16 pm
  • 1
  • 2
  • It is currently Mon Aug 24, 2026 6:39 pm
