Re: No channels since ProgDVB 6.7
#34
Yes, it's the same device, Hauppage USB Nova-T (DVB-T). Disabling "Use ITunerReqest" doesn't help.
Signal strength is great but it just doesn't find any channels... it's strange. Can I help run any debug of some kind?
Other 3rd party applications are fine so its not an issue with the device.
#44
Exactly the same.
I checked with the app that came with the tv tuner and it said some of the channels were on 642,000mhz so I tried that. I also had it auto scan through all UK frequencies but nothing.
One thing I did notice is that the antenna location I used to use is now missing from the UK list. Could it be skipping the frequency used by my local antenna?
