Hi,
since i have updated to ProgDVB v6.7X.X my Hauppauge WinTV-Nova-TD-Stick (Model: 958xx, DVB-T)
doesn't find any tv-channel. After deinstallation and re-installation of ProgDVB v6.65.2 it found some
channels in my area, but not all. After another downgrade to ProgDVB v6.63.10 all works fine again.
What can i do, to get the newest version of ProgDVB working?
Best regards,
Chris
Re: No channels since ProgDVB 6.7
#2Please compare settings in Settings->Device options.
Is it same?
Is it same?
#3The settings between ProgDVB 6.63 and 6.7X are different:
After I have changed the settings of ProgDVB 6.7, the search has found 4 channels of 27 (in my area).
#4I am recommend set "Not use more use device" for hauppage. But that is important only for dual tuner device.
#5Did you mean the option 'Not start more one device at one'?
In the meantime I've upgraded to ProgDVB 6.72.8 and I have also tested the above option, unfortunately not successful.
Any idea?
Any idea?
#6A month ago i have written a mail to ProgDVB-Support and i got no response!
One or two weeks later i created this forum post and till now i can't use ProgDVB.
In between i have bought ProgDVB Pro and i want to use the record function.
So ProgDVB-Support please help me!
#7I am not have idea about that. But you can try 2-3 simple experiments with Device Settings dialog. Also what version you use? Try x32 at first.
#8The facts!
01. ProgDVB 6.63.10 x64 and older versions working fine on my PC (timeshift is buggy and my pro-license is not valid with this versions)
02. After I updated to ProgDVB v6.65.2, it found only 4 channels.
03. After a another update to ProgDVB v6.7.x, it has not found any channel.
04. All the time i have had installed the newest driver of my Hauppauge WinTV Nova-TD (Model: 958xx) in Version 3.11.27187.
05. During the start process of ProgDVB x86/x32 an exception is thrown.
06. Changing the device options does not work.
07. My Specs: Windows 7 Ultimate x64 + Hauppauge WinTV Nova-TD (Model: 958xx) + Hauppauge Driver-Version 3.11.27187
Questions
01. What was changed from ProgDVB 6.63.10 to v6.65.2 and to v6.7.x?
02. Which versions are still between ProgDVB 6.63.10 and v6.65.2? So i can find the latest runing version for you.
03. How about a remote desktop session on my PC?
Questions
#9Tests
01. ProgDVB 6.65 - Found no channel without Option 'ITunerRequest'.
02. ProgDVB 6.65 - Found all channel. (Device settings like in the Screenshot of ProgDVB 6.63.10)
03. ProgDVB 6.65.2 - Found no channel without Option 'ITunerRequest'.
04. ProgDVB 6.65.2 - Found all channel. (Device settings like in the Screenshot of ProgDVB 6.63.10)
05. ProgDVB 6.73.1 - Found no channel without Option 'ITunerRequest'.
06. ProgDVB 6.73.1 - Found no channel. (Device settings like in the Screenshot of ProgDVB 6.63.10)
Notes
01. I have found out that ProgDVB 6.7 searches channels from 1 to 198 (Steps), but ProgDVB 6.6 searches from 1 to 188 (Steps).
02. I have selected the transponderlist-region 'Germany' without selecting a city (like ever before).
03. It seems to be that the transponderlist for Germany is changed and wrong in ProgDVB 6.7.x!
Notes
#10Do you have problem in Manual Scanner dialog with manual parameters?
#11What did you mean? I can open and search in manual search dialog.Do you have problem in Manual Scanner dialog with manual parameters?
Tests
07. I copied the transponderlist of directory 'ProgDVB-Dir\Transponders\TerFiles' from ProgDVB 6.63 to 6.7.x, but this has brought no improvement. Still no channels are found, so the transponderlist seems to be okay.
Notes
05. Could it be a problem that my Hauppauge WinTV Nova-TD has a TwinTuner (Dual-Tuner with Diversity)?
#12No problem if you enable "use only one tuner at once" in Settings->Device options.
#13Tests
08. ProgDVB 6.73.1 - Found no channel. Device settings like in the Screenshot of ProgDVB 6.63.10 but with Option 'Not start more one device at one' ...pretty English
or as you said 'use only one tuner at once'
Changelog (since 6.7)
ProgDVB 6.70.3 (12.08.2011)
- ProgDVB v6.70.3. Improve of multi-channel playback. Dual Tuner support + possibility not to close the device and timeshift during switching on the channel from other device or iptv. You can back to old channel without lost of timeshift. Support of Multi-stream transponders and hardware blindscanner. In this version only over CrazyCat modules (At this moment for Prof 7500 and Omicom). Remake Scan Transponder dialog + some improves of scanner. New settings and lot of fixes. New Splash window.
ProgDVB 6.70.5 (21.08.2011)
- ProgDVB v6.70.5. Update of network modules. Improve Prog Demux and other fixes. - Other fixes? What?
ProgDVB 6.70.6 (26.08.2011)
- ProgDVB v6.70.6. Fixes. - Fixes? What?
ProgDVB 6.71 (09.09.2011)
- ProgDVB v6.71. Import of IPTV channel from M3U lists without scanning, import XmlTV and logo data from m3u. Remake XmlTV channel relations. Support more one source of IPTV channels. Possibility to change icon in properties of the channel.
ProgDVB 6.71.1 (10.09.2011)
- ProgDVB v6.71.1. Fixes of positioner
ProgDVB 6.72 (17.09.2011)
- ProgDVB v6.72. Added support of DVB-S2 and h.264/AVC channels to freeware version of ProgDVB. But recording and diseq functions only in ProgDVB Pro. Added CrazyCat modules for TBS, TechonTrend and Omicom. Lot of fixes and optimizations. - Lot of fixes and optimizations? What?
Questions
04. Is the ProgDVB-Team using a BugTracker?
Notes
06. I'll try ProgDVB 6.70.3, if this version makes problems, then we have found the version in which the error occurs.
Questions
Notes
#14Tests
08. ProgDVB 6.70.3 - Found all channel. (Device settings like in this new Screenshot)
09. ProgDVB 6.70.5 - Found no channel. (Device settings like in this new Screenshot)
10. ProgDVB 6.70.6 - Found no channel. (Device settings like in this new Screenshot)
Notes
07. It seems that the bad ProgDVB version (6.70.5) was found!
Questions
05. What has changed in detail in ProgDVB 6.70.5?
Notes
Questions
#15Thanks for test. I spend more time for compare with 6.70.3. Please test last prerelease of ProgDVB also.
