Re: Recording with progDVB
#32Ok no problem in more attempts.
but in "prerelease "d" there are shortcut it name: ProgTV.. Next to the usual shortcut ProgDVB
Is installing a different program for older versions way? Does this shortcut located by running the program Options his benefit?
#33Must be ProgTV and ProgDVB (2 shoutcuts). But you must start ProgDVB(!). Please test "e"
#35now "e" prerelease is working " in portable mode in c:\ProgDVB...
but in record gave me the message in picture:
#36Thanks for the testing!
But now I need logs.
ps: try change transcoding settings in Option->Record.
#37There is no log file in folder log
in "ts" or "mpg" extension the record is working.. but i want record with "wmv" extension Because when I record with "ts" extension or "mpg" extension the one minute take 30 MB, however with extension "wmv" take 5.5 Mb, next to the possibility of rapid montage with extension "wmv"
I work in the managing editor of the Egyptian Al-Ahly club channel. This is very important for my work.. and I have two copies of the licensing of the software "ProgDVB" purchased from your company, one of the computer and the other for a laptop..
Please help
Please help
#39yes, in folder Log 11 file... any file you want?
show in the picture attachment
- 555.jpg (33.04 KiB) Viewed 5271 times
#40ProgDVBEngine.log. You can zip is and send me or add to forum in attach.
#41pls open file zip attachment
- ProgDVBEngine.rar
- (23.56 KiB) Downloaded 187 times
#42You select not good video mpeg2 codec in Settings->Options->Video->Codecs
#43i'm not select any thing... What do you recommend? ... Why he chose to solve the problem?
#45May be some settings of FFD not good. But this codec not working in ProgDVB for playback channel and for transcoding also.
