Good Morning
We are facing a problem in recording using your "progDVB" even the version# 6.73 with the xx.wmv extension but with the new versions although we are using the same extension but the final result is xx.ts extension. yesterday i'm install the last version. the final result is xx.ts extension.. I wont Record with extension xxx.wmv
Please help to solve this problem.
Re: Recording with progDVB
#5Now carried the "ProgDVB7.07.5Pro" version and gave me these messages as pictures:
#7With "47.7.7" the same result ... and how to give the program does not open and gives me the previous images sent ?, Give me the way
#8I mean, after installing the latest version of the program remains the first image and then gives me a second and never opens ...
#10Date problem recording with extension "ts" started from version 6.73, I want to recording with extension "wmv"...with version 6.73 the recording is good with extension "wmv"
now i'm installing version "6.72" it's worked well and recording are also extension "wmv"... Good... is an excellent copy but make very slow my PC...
Last edited by Muhammad Moustafa on Sat Dec 20, 2014 7:51 pm, edited 1 time in total.
#11A very big problem ... the computer in a very slow when Start Recording Vedio... pls help me
Is there a solution to the problem of slow computer ?, was not the case before
#12wmv recording request transcoding. And that is not good idea for slow PC. I am recommend record to TS if you not have power CPU.
#13The combuter is very slow if i'm recording vedio from channels with "wmv" extension or "ts" extension.. this is problem
I'm privileged to be working with the version of "6.72". recording vedio from channels is along the "wmv".. good. but I hope you tips to resolve slow when recording vedio from channels, computer very good speed and image attachment to the speed of its components, and the slowness comes when recording vedio only.
This is a new problem, did not occur before with the same version "6.72"
I have two copies of the licensing of the software "ProgDVB" purchased from your company, one of the computer and the other for a laptop..
pls help me
pls help me
- Af. 89.JPG (5.7 KiB) Viewed 8396 times
#14.ts/.wmv extension is not depended from CPU (this is bug). Please use modern version.
but you must have some addition CPU power for record to wmv.
#15i'm trying install new version the "ProgDVB7.07.5Pro" version. the program does not Open and gave me these messages as pictures:
