Presently it's the 'New Blue Skin v5'. I modified this by the skin editor, changing the background colour of the channel list from white to black and the colour of the letters from black to white which is much more comfortable when watching tv - highly recommandable. This should not be the problem, as I tried out, of course, all other (unmodified) skins and its the same there.
EDIT:
Problem seems to be solved now. All old skins seem to be "not compatible" with the newer ProgDVB versions. The new skins work now. (Why isn't that stated in the 'news' ?).
report
#382hi
i have poroblem with prog and it's sometime's when i chenge tv channels ( free or scrambled ) i can hear the voice of channel but the screen is black with no picture and even the osd is not visible and only way to fix it is restarting progdvb. for example i change it to viva ind iget the back screen with voice of curent channel but wen i change it again to rtl i have tv channel normaly with no problem but when i again get back to viva (hear we go again ) i still have same issue.
now i use the lastest 6.11.05 and im stil facing this probem .
and the other thing is somtimes on some channels voice comes about 10 sec to 1 min after the picture and some time it never comes so u have to watch it like a deaf person
and again i have to restart progdvb.
thx
thx
6.11.6
#384Crashes during ProgDVB closing with this error message (all modules disabled, no plugin):
System.MissingMethodException: Method not found: 'Boolean System.Threading.WaitHandle.WaitOne(Int32)'.
at ..()
at ProgDvbNet.MainForm.(Object , FormClosingEventArgs )
at System.Windows.Forms.Form.OnFormClosing(FormClosingEventArgs e)
at IPDev.Skins.Docking.DockForm.OnFormClosing(FormClosingEventArgs e)
at System.Windows.Forms.Form.WmClose(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at IPDev.Skins.Docking.DockForm.WndProc(Message& m)
at IPDev.Skins.SkinForm.WndProc(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
ProgDvbNet
Assembly Version: 6.11.6.0
Win32 Version: 6.11.06
CodeBase: file:///d:/Aplikace/ProgDVBpokus/ProgDvbNet.exe
EngineApiWrapper
Assembly Version: 1.2.12.0
Win32 Version:
CodeBase: file:///d:/Aplikace/ProgDVBpokus/EngineApiWrapper.DLL
msvcm80
Assembly Version: 8.0.50608.0
Win32 Version: 8.00.50727.42
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0de06acd/msvcm80.dll
System
System.Drawing
ProgDvbNet.bc
Assembly Version: 1.0.3.0
Win32 Version: 1.0.3.0
CodeBase: file:///d:/Aplikace/ProgDVBpokus/ProgDvbNet.bc.DLL
IPDev.Skins
Assembly Version: 1.3.16.0
Win32 Version: 1.3.16.0
CodeBase: file:///d:/Aplikace/ProgDVBpokus/IPDev.Skins.DLL
ProgDvbNet.EPG
Assembly Version: 1.0.6.0
Win32 Version: 1.0.6.0
CodeBase: file:///d:/Aplikace/ProgDVBpokus/ProgDvbNet.EPG.DLL
ProgDvbNet.CC
Assembly Version: 1.0.4.0
Win32 Version: 1.0.4.0
CodeBase: file:///d:/Aplikace/ProgDVBpokus/ProgDvbNet.CC.DLL
ProgDvbNet.Win
Assembly Version: 1.0.0.0
Win32 Version:
CodeBase: file:///d:/Aplikace/ProgDVBpokus/ProgDvbNet.Win.DLL
Accessibility
System.Design
System.Xml
System.Drawing.Design
enabled.
For example:
<configuration>
</configuration>
at ..()
mscorlib
ProgDvbNet
EngineApiWrapper
Win32 Version:
msvcm80
System
System.Drawing
ProgDvbNet.bc
IPDev.Skins
ProgDvbNet.EPG
ProgDvbNet.CC
ProgDvbNet.Win
Win32 Version:
Accessibility
System.Design
System.Xml
enabled.
For example:
<configuration>
</configuration>
possible bug with radio/audio
#386since a few version i observe a possible bug: if i turn on radio and let it run for some while (lets say 45-60 minutes), clicking noises are hearable. it starts slowly, but with time it is more and more. realoading the channel fixes it for another 45-60 minutes.
it also use dvb dream (as progdvb + cnxcam does not decode ECM) and this problem is not occuring.
hardware: skystar 2 pci, phenom x4 (same problem with previus athlonex2 cpu) 4 gb ram, win xp sp3 (32 bit), nvidia chipset and gfx, sb live 5.1, cyberlink power dvd (PDVD8) codecs.
stream: hotbird 13°E, Cyfra+PR, stream 3 - 10.892 GHz H, PID 118 (pr3)
6.11.08 totally unusable
#3876.11.08 totally unusable, needs constantly 100 % CPU load, garbled picture and sound, computer almost completely stuck. After overinstallment of 6.11.07 same bad result. After uninstallment and re- installment of 6.11.07 okay again. Stick to this old version until next one.
Re: 6.11.08 totally unusable
#388Please send me more details about your system over email.olugu wrote:6.11.08 totally unusable, needs constantly 100 % CPU load, garbled picture and sound, computer almost completely stuck. After overinstallment of 6.11.07 same bad result. After uninstallment and re- installment of 6.11.07 okay again. Stick to this old version until next one.
#389
Can't switch transport streams with Reddo DVB-T USB.
After choosing a channel with TVJukeBox, ProgDVB can view channels in the same stream but not others.
Program guide works for all the channels.
