No. This is not fix but search direction for me.
Please test every Engine and report what engine is crash
http://files4.progdvb.com/test/21/ProgD ... xcount.zip
http://files4.progdvb.com/test/21/ProgD ... odules.zip
http://files4.progdvb.com/test/21/ProgD ... .prov1.zip
http://files4.progdvb.com/test/21/ProgDvbEngine.sdp.zip
Re: 0xc0000005 and 0xc0000374 errors with the latest version of the ProgDVB with IPTV
#62all 4 engines are crashing immediately on startup
#64This one does indeed workProg wrote: ↑Sun May 04, 2025 2:15 pm
Please try new prerelease https://www.progdvb.com/download_progdv ... lease.html
edit : sorry I tested the wrong version. The pro version crashes. The free version works
#65please try free version of prerelease. Is it working also?
#66sorry I made a mistake in my previous test. I downloaded and tested the free version (instead of the pro), and it works.
but now I tested the ProgDVB7.66.3c.Pro.exe and it still crashes
(I think I made the same mistake with the b version, I downloaded and installed ProgDVB7.66.3b.Std.exe instead of pro, I assume the pro version crashed as well)
#67I am back all changes and public "d" version. Still crash?
#68unfortunately, yes
ProgDVB7.66.3d.Pro.exe --> crash
#70still no luck
ProgDVB7.66.3e.Pro.exe --> crash at startup
#71Thanks. One more prerelease "f"
#72And I need logs from last prerelease.
#73it's not possible to get an extra verbose release just to point you in the right direction ?
#74"f" Pro crashes
Logs attached
Logs attached
- Logs.zip
- (250.23 KiB) Downloaded 448 times
#75quack: I add new logs information to every prerelease.
phobbes: Thanks! very important log for me.
I am upload new prerelease. Please send me logs if still crash.
