ProgDVB Crash when Rus As Administrator dialog show
jackjack
jackjack
Sat Oct 29, 2016 3:52 pm
#1 by jackjack
Hello
when you are watching ProgDVB , if you open another program that it need UAC (Run as administrator Dialog) , the Progdvb video will be pause and it crash
what should i do ?
  • Fri May 05, 2017 5:31 am
Re: ProgDVB Crash when Rus As Administrator dialog show
Try change video renderer in Options->Video->Codecs
  • Fri May 05, 2017 12:48 pm
jackjack
jackjack
#3 by jackjack
Prog wrote:Try change video renderer in Options->Video->Codecs
Thanks
current codec is :
EVR Custom presenter
which codec would you prefer ?
i have tested other codec but the problem didn't fix
  • Sat May 06, 2017 3:19 am
#4 by Prog
It is not codec problem. It is render problem. You can try not custom render.
  • Sun May 07, 2017 3:33 am
jackjack
jackjack
#5 by jackjack
Prog wrote:It is not codec problem. It is render problem. You can try not custom render.
I test other render but problem didnt solve
how should i do ?
  • Mon May 08, 2017 3:27 pm
Вы мне логи крашей присылали?
  • It is currently Fri Jun 26, 2026 4:34 pm
