where is the file inside the logs folder
where is reported the crashes of the program ?
thank.
Re: crash
#7hi, i think your program is not made right now for support a octa-tuner card.
after crash all morning, i have uninstalled the 32 bit program.
i have take the new windows 10 driver for the card tbs 6209.
i have reinstall the 32 bit program.
at the start, without touch, the program has turn on all 8 tuners.
after some crashes, i was able to turn off the last tuners.
right now i do the channel search for the first 4 tuner that
your program has always work fine.
the problem appear later, when i try to open the last 4 tuners.
if you solve the problem of all these crashes, i buy the 64 bit
program also today.
program also today.
