Re: Right to Left languages
Mon Oct 02, 2017 10:48 am
Still wait sample of stream with RTL in channel names.
Please explain What do you mean by "stream with RTL" - do you asking for a screenshot to see how the EPG OSD looks like?
ALSO -
Please specify the changes you made in the test version, so we know what to test...
Right now I don't see any difference between the standard version and the RTL test version :-(
Can't Record " Service->start recording->All ts and record me 5 minutes of stream"
I got the message - "ONLY PRO VERSION.... Want to upgrade?"
Attached is a screenshot of the OSD Descrioption and Channels ...
Text should be align to right (3 dots should be at the left...)
(...info info info, 13 episode - series sample)
(...דוגמה לסדרה - פרק 13, תיאור תיאור תיאור)
and - a link to m3u and EPG with hebrew text for you to test:
m3u file (free online and legel): attached
EPG link: http://goo.gl/8xvt74
Thanks again.
HebEPGsample.zip
m3u file (in the zip file)
(528 Bytes) Downloaded 137 times
RTL Needed screenshot
Tue Oct 03, 2017 1:51 pm
Check Options->Modules->TS recorded=enabled
I don't have "Modules->TS recorded=enabled..."
Listen my friend... I sent you the m3u file, and the hebrew epg...
Put them in your "TV Sources" - and record what ever you need...
IT WILL BE LIKE YOU SEE WHAT I SEE!!!!
