ProgDVB crashes when checking for updates
quack
quack
Mon Jun 27, 2016 5:28 pm
#1 by quack
Hi,
I'm using ProgDVB 7.22.9 and when I check for updates, it crashes.
See logs here :
prev1.rar
(8.54 KiB) Downloaded 228 times
I had no issue with 7.21.x releases.
Thank you
  • Fri Feb 09, 2018 8:24 pm
Re: ProgDVB crashes when checking for updates
Only on update? Try disable IPTV sources. Still crash?
  • Fri Feb 09, 2018 9:08 pm
#3 by Prog
Try prerelease version.
  • Fri Feb 09, 2018 10:59 pm
quack
quack
#4 by quack
I can't disable IPTV as it's what I'm using ProgDVB for.
I tried with prerelease, same bug
  • Sat Feb 10, 2018 12:27 pm
quack
quack
#5 by quack
the bug appeared in version 7.22.8
in version 7.22.7 it's working ok
  • Sat Feb 10, 2018 12:29 pm
quack
quack
#6 by quack
any clue ?
  • Thu Feb 15, 2018 9:31 pm
#7 by Prog
Do you test 7.23?
  • Fri Feb 16, 2018 6:26 am
quack
quack
#8 by quack
7.23 fixed it !
thank you
  • Fri Feb 16, 2018 11:57 am
  • It is currently Mon Aug 24, 2026 8:09 am
