Minimizing the file i recorded by ProgDVB ?
Hi all,
I've recorded a film from the ProgDVB program, its 90 miutes, I've been surprised with the SIZE of the recorded file !i! about 3 GB of space.
Is there any idea or program that makes it about 700MB, to be copied to one CD?
Plz HeLp, thanks all
thanks for replying .. but can you specify the name of that program .
No , this depends on to what do you want convert your record files...
btw. This is progdvb support forum !. Nothing else .
i have used the Video Convert Master program to convert from MPG to AVI Divx but the output file sound with out picture
SiLencer wrote: This is progdvb support forum !. Nothing else.
You will find a video reprocessing section at DVBN, for example.
Aslo possible, you have to run your recordings through PVAStrumento first, or simply de- and remux.
However, this is a ProgDVB dedicated place, and nothing but that.
CLOSED
