Hi.. after updating at 7.24.07 version the software import epg but are not visibles
I have a Subscription with xtream-editor.com where arrange my lists with logos and epgs..
Since 2-3 days ago all works good. now import the file but ara visibles only the logos, epg guide is not visible in all channles. not visible in the channel menus and the skin. both..
i have also removed and installed another time the progdvb but nothing change..
iìm not shure that the problem is the new version but since 2-3 ago all works good
Re: ProgDVB 7.24.07 problem with epg's
#2Can you give me your account for test?
Or send me logs for more information.
#3tested now with 7.24.6 and epg are visbles.. the problem is in the 7.24.7
i use win 10 x64 and x64 version of progdvb..
#5where is the log in a Pc with Windows 10 ? which folder ? i can give my login man.. is a private and personal login…
now i have the old version, i must er install the new in other pc...
#8Please send me your data folder of ProgDVB. I am not can repeat problem on my PC.
#9This is xmltv? I am need data folder of ProgDVB with all settings and links. For repeat on problem.
ps: I will test only update. No TV channels.
#11You can try remove Channels\*XmlTvRel.dat files and update again for create new links for epg.
#12Sny news ? epg still not working.. Installing from ZERO ( clean PC ) same problem..
#15tested now with a clean installation, nothing changes..Prog wrote: ↑Wed Aug 22, 2018 8:06 pmPlease try http://www.progdvb.com/download_progdvb_prerelease.html
