Hello there!
I have a Hauppage HVR-3000 installed and working with Vista 32 OS. Using the ProgDVB version 4.56.2 with BDA are working great for DVB-T and DVB-S (no Analogue though). The problem is that when changing from one device to the other (BDA DVB-T to BDA DVB-S, and viceversa) the program becomes unstable and I have to close it. When re-open the new selected device works.
My question is: Is there any way to change from one device to the other without the needed of closing the program? If so, how do i do it?
Thanks very much for your help.
PS. Really great program
Not reallyMy question is: Is there any way to change from one device to the other without the needed of closing the program?
Try a newer progdvb version...
p.s.
ProgDVB is NOT meant to work on any analogue tuners, better forget about that at once.
You have to use another software for this part.
