Can't save custom audio pid ?
Hi.. I have a channel that I'm defining with video & audio pids, as mentioned elsewhere, the video doesnt display until the audio pid is entered, however when I navigate away from the channel & come back the custom audio pid is gone, the dropdown is blank again, and theres no video until I go back in and re-enter the audio pid.
I've tried with 'Unknown' and a few language types, no difference. I am adding the pid (rather than editing an existing), as there are no existing defined for this channel.
I did have a look at progdvb 5, but that seems to have removed the option to edit video/audio pids entirely.. can only edit pcr etc.. Hoping that progdvb5 re-adds the ability to edit this stuff, as too many other viewers are enforcing using supplied data from pat/pmt, and progdvb was one of the nice remaining power tools to define custom channels...
In 5x you can:
1. Edit default language list in Options.
2. Edit language list in channel property.
3. Select audio stream manual if disable "can update" check box.
