Delete m3u lists and IPTV Client permanently.
LeoJarek
LeoJarek
Fri Oct 06, 2017 12:04 pm
#1 by LeoJarek
Hi.I have problems with the lists that I supposedly deleted by entering the channel editor. Each time when I update the deleted lists they appear again. These lists are no longer valid or those that I do not use
  • Tue Oct 09, 2018 10:39 am
Re: Delete m3u lists and IPTV Client permanently.
Do you like use list from site or local list after edit?
  • Tue Oct 09, 2018 1:03 pm
LeoJarek
LeoJarek
#3 by LeoJarek
I use the two kinds of lists. I want to say that the lists are from a specific site without editing and also others I download edit and then I install them in the program. It's the only problem I have. For the rest, the program works very well.
  • Tue Oct 09, 2018 1:30 pm
  • It is currently Mon Aug 24, 2026 5:20 am
