If I do a clean install of 7.26.1, the Multiplexs window does not show any Region or frequencies. If I install an old version 7.25.4 it works fine. If I install 7.26.1 over 7.25.4, quick update, it works fine.
The installer of 7.26.1 seems to be missing some files or settings.
Re: Multiplexs is broken for new install
#3DVB-C
I have Terratec with 2xDVB-T + 1xDVB-C. But I use only DVB-C.
#6Still does not work. I tested a clean install with ProgDVB7.26.2a.Std
Also, a minor bug is when you uninstall ProgDVB, the language folders hr-HR and sr-cyrl-rs are remaining on the computer.
#8Shared settings for all users.
Select only Digital TV Device.
Default. Next.
Select only Tray tool...
Install
Default. Next.
Install
#9I found another bug.
If I click Back, the BDA device multiplies
Also, Prog Media Server Module is installed even if I uncheck the option.
#10I am still not can repeat mux problem. Try uninstall and install again. And check version number.
#11Tried again... Clean install. Uninstalled, removed program files (x86)\ProgDVB and Programdata\ProgDVB
Installed ProgDVB7.26.2a, mux windows is broken.
#12I found something helpful maybe. I replaced these files with the files from version 7.25.4, and the multiplexes windows works ok.
EngineApiBase.dll
EngineApiWrapper.dll
ProgDVB.Common.dll
ProgDvbNet.Win.dll
ProgDvbNet.bc.dll
ProgDvbNet.CD.dll
ProgDVBNet.EPG.dll
ProvidersEngine.dll
ProgDvbNet.exe
So the installer is not the problem.
EngineApiBase.dll
ProgDVB.Common.dll
ProgDvbNet.Win.dll
ProgDvbNet.bc.dll
ProgDvbNet.CD.dll
ProgDVBNet.EPG.dll
ProvidersEngine.dll
ProgDvbNet.exe
#13Installed all the consecutive versions.
7.25.6 the last good working version
7.25.7 the version where the bug first appears
Hope it helps.
P.S. I found this bug on clean install, because I needed to search channels. On quick upgrade, I already had the channels, so I did not see the multiplex window bug. That is why I first believed is only for clean install.
Hope it helps.
#14More changes in .3 release. Please try install not to program files if still problem in release.
#15Tested 7.26.3 and still does not work. Tried to install in a different folder, but the same problem appears.
