Stuck at EPG loading !
Hello,
I have got an m3u_plus link to try and load channel guides.
But for some reason the update gets stuck not progressing anymore !!!
Since, the guide doesnt update automatically by loading the m3u link to receive /update channels. I did put the same link via the guide tab, and there's where it get stuck when i try to receive / update the guidelist!!
Is it normal, it takes so extreme long to load guide for the first time, or is there something else going on i!?
Using the M3U_plus link on my iptv box (formuler) is no problem at al , and loads/updates the epg guide from the link though !
Many thanks in advance,
cheers,
TD
Current Main System:
MOBO: Sabretooth FX990 R2.0
CPU: FX-8350BE@4,7Ghz
Cooling: NZXT x52
GPU: RX580 8GB
SSD: Samsung EVO 850 250GB
RAM: 16GB PC3-12800 Quad Channel
Monitor: MSI Optix G27C2
OS: Windows 10 x64 Pro
Re: Stuck at EPG loading !
Sat Dec 22, 2018 5:55 am
What error message? Can you share me this m3u? (in PM or email)
No error message, the process seems to hang/freez .. ! It keeps loading and loading and loading and never ends !
Btw, do you need the full M3U playlist (login/pass included !?)!
If so, i'l pm it in that case.
EDIT: As attachement you can find the logs concerning EPG loading !
EDIT 2 update: I have check the url on another device, and it has indeed NO epg data. So this matter is closed !
cheers,
TD,
Cooling: NZXT x52
GPU: RX580 8GB
EPG loading!
(252.9 KiB) Downloaded 211 times
