Cannot access plugins dropdown menu
I've had several issues regarding progdvb5.08 version.
Most of them i've solved, but there is something i couldn't:
Why doesn't show anything under the plugins menu ?
the plugin is loaded, because it's icon shows in the system tray, but i can't find it in the plugins menu so i cannot configure it.
I'm using windows vista ultimate with SS2.
No idea on Vista, nor even on latest 5.x versions, sorry.
But AFAIK most plugins also have .ini files, that could be edited easily.
However, Prog is right, menues not showing up (or leading to crash) in most cases are language file depending.
Language files base on exe style real code (resp. ressource numbers and type), far more that just plain text.
You need a suitable ressource handling tool to build those porperly.
And they may even depend on Windows localisation.
And in case also on skins...
Always take care to use the language file that REALLY suits the exe version.
And if English, use the one that came with it.
Every GUI change of ProgDVB requires a similar language file change, in every language.
