ok sry no problem
first of all, thank you for your quick reply
i think i kind of missunterstood the API system
it seems to only work for plugins that are directly loaded via ProgDVB
what i thought first was, that any external software (.exe file) can access ProgDVB via it's hWnd and SendMessage to get / send information from/to it but that was wrong wasn't it?
my problem is that it's a bit tricky to do recordings over the integrated scheduler because sometimes channels change only after the second click on them. so to schedule a record i set the channel twice (with 1 minute between the schedules) and as i wanted to record a program every day at specific times.. this is a bit annoying.
is there any plugin for easier scheduling? or would it be better to manually modify the schedule.ini and restart ProgDVB?
thx for help and sorry for the german
