Have been using version 4 for a while now but decided to try version 5 hoping to have more luck watching HDTV. Unfortunately when trying to run the program progdvbnet.exe crashes before the program even appears. I am running Vista 64-bit and suspect this to be the reason it crashes. The following is the information from the event viewer on the error in case it is of use.
The description for Event ID 1000 from source Application Error cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
ProgDvbNet.exe
5.8.2.0
463afa3a
KERNEL32.dll
6.0.6000.16386
4549d328
e0434f4d
00000000000233ac
The substitution string for insert index (%1) could not be found
MrMB
