guide time not advancing
1 post
Fireneg
Fireneg
Thu May 02, 2019 8:58 pm
#1 by Fireneg
Hi, running version 2.51.8 of progtv and when I go to epg I have a list of 7-8 channels with time from 4 to 7 o'clock and when I try to scroll in guide past 7 o'clock the guide does not change like from 7 to 8 then 8 to 9 it stays fix at that time of day. I did put the update to 1 hour but when I click update I see like an arrow circle pop up but its not rolling or anything ans does nothing in guide. Thank-you for the help
  • Thu May 02, 2019 9:13 pm
1 post
Return to “ProgTV Android”
Since you're experiencing crashes while scanning satellite transponders and audio/video glitches after moving to Windows
carlos_guerrerom, Thu Oct 22, 2026 11:53 am
Re: проблемма со звуком
Попытка поправить работу с eac3 в пререлизе
Prog, Sat Oct 17, 2026 6:44 pm
Re: Вывод звука wasapi и asio
Снава столкнулся с глюками asio. Поправил в пререлизе.
  • It is currently Fri Oct 23, 2026 5:48 am
