A graph must suit your system.
That's even more important, as HD is a real ressource eater
Any piece of HW support you could get from your VGA might be pretty helpful.
This for, you should create your own one with graphedit.
You need a (short) recording for this, that can even be done with PC screen picture not yet working.
That's all from me on that issue, as my hardware is not HD ready at all.
how should i record a hd streams without support of purevideo HD codec in progdvb :S
EDIT: normal TV workx fine with silencers purevideo graphfile. my VGA card is a 7950 GX 2 so there is a big support against software rendering. can somebody give me a plain instruction how to create my graph for HD ?
i got the graph. BUT i just cant change the cyberlink codec with the nvidia purevideo. did u know the exact filter name of the purevideo codec and where i can find it :S greetz spaxx
EDIT: if i render a non HD channel to a graph, he didnt use the purevideo codec to play it back, but if i watch progdvb it uses the purevideo codec :S
