SiLencer wrote:the channellist you use ...fresh scanned or an imorted list from an other progdvb version ?
Fresh scan ... maybe i have an useful detail
( when do copy/past (channel ) >> exit/run ( progdvb ) i have new channelist with the same name ( also old bug from the first Version )
Perhaps you should use Favourites lists, instead of editing the original / dynamic ones.
BTW, the first versions, 1.x to late 2.x (at least) did NOT have an issue like this.
later on, there came a limitation, that just one station of a dynamic list could be deleted or added at a time, ProgDVB restart required.
AFAIK, Prog did work on that recently, but I'm still not touching the dynamic lists over here.
If you want to cover up some nasty stations, either edit their V + A IDs to invalid / foreign values, set to not update, or simply don't let the dynamic lists be shown at all, favs only.
Juergen wrote:Perhaps you should use Favourites lists, instead of editing the original / dynamic ones.
Ok , Thanx for ur explanations and points ( but i had never used Fav. channelist )
good luck
