7.30.02 Bug - OSD Locked
flaviote
flaviote
Sun Jan 27, 2019 11:43 pm
#1 by flaviote
After updated to that version, the OSD, using IPTV services, is stuck, saying "Analyizing" string.
Went back to 7.30.01 and this doesn't happens.
  • Mon Dec 09, 2019 11:06 pm
Re: 7.30.02 Bug - OSD Locked
Send me link on this channel
  • Tue Dec 10, 2019 6:12 am
flaviote
flaviote
#3 by flaviote
This is an example.
In 7.30.03 the Bug still happening.
I am a Network edition paid user.
  • Thu Dec 12, 2019 9:30 pm
flaviote
flaviote
#4 by flaviote
This bug will be corrected?
The software is unusable for IPTV with this problem...
7.31.02 has the BUG also
  • Sun Dec 22, 2019 12:53 pm
#5 by Prog
I am still waiting for you more information. Please send me logs.
Enable Options->Debug->Logs and send me all logs files after repeat of problem.
  • Sun Dec 22, 2019 3:48 pm
flaviote
flaviote
#6 by flaviote
Good, i've uploaded the logs.
Just opened the application, the last channel was opened, OSD with loading appears OK, but after that, a background OSD still alive.
Will take a short video to be uploaded.
https://drive.google.com/file/d/1l5-fR_ ... sp=sharing
  • Sun Dec 22, 2019 4:48 pm
flaviote
flaviote
#7 by flaviote
Here is the video:
https://drive.google.com/file/d/1rQeStS ... sp=sharing
  • Sun Dec 22, 2019 4:56 pm
#8 by Prog
Audio codec (6ac7c19e-8ca0-4e3d-9a9f-2881de29e0ac what codec?) not good for ADTS audio. Please try use other audio codec.
  • Sun Dec 22, 2019 5:01 pm
flaviote
flaviote
#9 by flaviote
Changed for another codec (AC3Filter) and the problem still happening.
New logs and new video:
https://drive.google.com/file/d/15ZKfC_ ... sp=sharing
https://drive.google.com/file/d/1KKgGWt ... sp=sharing
  • Tue Dec 24, 2019 1:37 am
#10 by Prog
Same error again. Do you try LAV codecs?
ps: Please record me sample of TV. Service-> TS recorder->ALL TS and record 3-5 minutes.
  • Tue Dec 24, 2019 7:19 am
flaviote
flaviote
#11 by flaviote
The problem was solved. Thanks.
But now, i have scaled and pixeled OSD.
Doesnt matter if you set the HD or SD OSD.
  • Mon Jan 20, 2020 3:47 pm
#12 by Prog
Do you have one monitor?
  • Mon Jan 20, 2020 4:02 pm
  • It is currently Mon Aug 24, 2026 3:47 am
