Sat>IP with prog dvb not really working
Hey everyone,
i have a very weird behavior on prog dvb using sat>ip tuner.
The channellist is destroying itsel. i can do a channel scan, select a programme and with luck i get a picture.
I recorded a video so there you can see this strange behavior.
If you scan multiple transponders, progdvb is only destroying channels on same transponder.
Already on the first tune, progdvb is overwriting the pid values with other things, then progdvb is requesting this invalid pids on the satip server and i'll get no picture or audio.
https://youtu.be/WNJKUONHL-k
edit:
Channel Update during watching is disabled.
kind regards
Re: Sat>IP with prog dvb not really working
With IPTV and RTSP Channel List i get ressource not found 404
the channellist is definetly working. it plays perfect in e.g. VLC media player or any other player.
i tried that before using sat>ip with no success.
with using http stream i get a picture (after disabling user authentication otherwise it is permamently asking for user and password)
but via http stream the media server is not transmitting ecm, emm or other non audio/video related streams.
kind regards
I'm using DVBViewer Media Server.
This thing provides me RTSP URLs as Channel List,
HTTP Streaming as Channel List and SAT>IP Protocol.
This Server is used by whole family and i am not able to install any other software. So i have to use my office computer to develop and test software with
prog dvb via one of that protocols above.
