Hello,
I have a problem with ProgDVB. 4.85.1.
After approximately 5 minutes runs the clay/tone faster than the picture. Picture and clay/tone are not synchronous.
What can I do?
Thanks
hi , as discussed many times (also in the old forum...)....set progdvb´s priority higher,try other codecs,close programms running in backround...
btw. never had such problems here ...
e.g. antivirus,firewall and other programms that needs cpu time or cause hdd activity...
btw. its better to timeshift in RAM ....
How should i know this...no problems here with timeshiftIs the problem timeshift?
its not possible to deactivate timeshift...you can only install progdvb without timeshift...thats all
And another time...this issue was discussed so many times (also here [old forum] http://forum.progdvb.com/ )...read...read...read
I do not find Thread to my problem.
You can say to me. how is to be settings from ProgDVB, so that it functions?
thanks
thanks
there is no generell solution for this...the given hints are always the same...you have to try out what works for you...
