Re: TV Sources crashes
Faulting application name: ProgDvbNet.exe, version: 7.32.4.1, time stamp: 0x5e4b9410
Faulting module name: pinnacle.Device, version: 0.0.0.0, time stamp: 0x446a15ac
Exception code: 0xc0000409
Fault offset: 0x000031a3
Faulting process ID: 0x2d18
Faulting application start time: 0x01d5e72798f08859
Faulting application path: C:\Program Files (x86)\ProgDVB\ProgDvbNet.exe
Faulting module path: C:\Program Files (x86)\ProgDVB\Modules\pinnacle.Device
Report ID: 17e88b36-a4f0-4a14-a5d5-a54af5bf3811
Faulting package full name:
Faulting package-relative application ID:
Faulting module name: ProgDvbEngine.DLL, version: 0.0.0.0, time stamp: 0x5e4b9569
Fault offset: 0x00316183
Faulting process ID: 0x1564
Faulting application start time: 0x01d5e72e742e4287
Faulting module path: C:\Program Files (x86)\ProgDVB\ProgDvbEngine.DLL
Report ID: a3d30a30-81e3-4739-bb73-6a54952c5e3c
I have now uninstalled the entire app, rebooted and reinstalled. Now have to rescan a zillion transponders over many sat positions (motorised dish) whcih sucks but TV Sources now does not crash. It is annoying as I have changed nothing recently except to update the app when it shows new version available.
Pinnacle device is no longer installed so perhaps there should be a cleaner option to remove old unused bits when installing updates? I see loads of items in the tv sources list that I care nothing about so they shouldn't be there unless installed I think.
Also, video codecs still freezes even after all this...
2 more things since clean install - Subtitles button is stuck on yellow (can't turn it off) and the audio and video are not in sync. Unable to change either video or audio codecs - both option just freeze the app before they even display the list.
Debug logs enabled.
