Help cannot use controls in options
cleggie
cleggie
Fri Jul 17, 2020 2:57 pm
#1 by cleggie
using latest version of progdvb pro (bought subscription.I am having a problem.When i go into options then try to go to controls it just closes the program every time.what is wrong.I need to change to use remote control but cannot get into controls to alter
  • Fri Jul 17, 2020 2:59 pm
Re: Help cannot use controls in options
Try remove or rename UnivHidRemoteControl.RcModule file.
  • Fri Jul 17, 2020 5:53 pm
cleggie
cleggie
#3 by cleggie
Thank you that worked
  • Fri Jul 17, 2020 6:03 pm
Вы мне логи крашей присылали?
  • It is currently Fri Jun 26, 2026 12:58 pm
