Hi There is a Problem with the EPG Update Scan on ProgDVB and ProgTV.
If I refresh the EPG the first one is the user custom link with the correct Channels and Timezone.
After this its scanns everytime the Provider EPG too. thats bad because the EPG from the Provider is not good. (Wrong Timezone wrong EPG)
Maybe someone can add the same options from IPTV Client to the Ministra(Stalker) Client to stop the Provider EPG.
Re: Ministra(Stalker) Provider EPG overwrites the User XmlTV links
#2Not good. Need some priority settings... Do you mean per channel or total disable Stalker EPG?
#3For me disable Provider EPG is good. Because i use the XmlTvRelation for all channels to use the Rytec EPG format.
Because the Providers often not use good EPG xmlTVs
#4May be some temporary solution if total disable stalker epg if field xmltv link. But not sure.
#5Ops. That impossible... Need new checkbox.
Do you use ProgDVB or ProgTV?
#6I use both Progdvb on PC and export to Progtv on android device. If its possible to deaktivate for both would be great.
#7I do that in one of next version. Too many changes in near days and I am not like add addition functions (and bugs
in next version.
ps: One question. Why you not use ProgTV on PC?
#8Ok thx for the response. I use Progdvb on windows for sort and set relation for EPG. After i export and import to Progtv on my firetv stick. Everything works fine until the EPG because of overwrite from Stalker provider epg.
I´m not using Progtv on PC.
br
br
#9Nice work!
With the latest updates on Progdvb (Windows) 7.35.9 & ProgTV (Android) 2.98 Beta there is no overwrite from Provider EPG.
Thanks!
Thanks!
#11maybe i change something and now it not overwrites anymore. I testet a lot
But i´m no expert
