Hello
I am from Austria and this is my first thread.
I have ProgDVB Vers. 4.84 on my PC installed. And i want do remote it with my Remote Control of my Pinnacle Card.
I tryed it with the Pinnacle Remote Control 3, but it doesnt work!
I hope you give me a full package of files, that it works!
thanks!
Hi , the original Pinnacle Remote Control
software must be installed and running ...and you need a proper ´profiles.ini´ for progdvb
I hope this works..its all that i can do for you ...
[progDVB]
;OSD Menu
key29=KEYBOARD o+^o
;OSD Kanalliste
key31=KEYBOARD l+^l
;OSD Kanalinfo
key43=KEYBOARD i+^i
;lastchannel
key37=KEYBOARD c+^c
;Volume-
key15=KEYBOARD NUMSUB+^NUMSUB
key79=KEYBOARD NUMSUB+^NUMSUB
;Volume+
key27=KEYBOARD NUMADD+^NUMADD
key91=KEYBOARD NUMADD+^NUMADD
;kanal zurück
key22=KEYBOARD z+^z
;kanal vor
key19=KEYBOARD v+^v
;Fullscreen
key45=KEYBOARD f+^f
;record
key39=KEYBOARD r+^r
;Mute
key60=KEYBOARD m+^m
;Kanalwechsel
key23=KEYBOARD DOWN+^DOWN
key28=KEYBOARD UP+^UP
;Normal/TV/Vollbild (erfordert Kommandoänderung)
key46=KEYBOARD ü+^ü
;Wechsele Audio Stream (erfordert Kommandoänderung)
key30=KEYBOARD ä+^ä
;*************************************#4
The Problem is, that the Header of ProgDVB is like: ProgDVB ['channelname']
PCTV Remote looks for this Header such as in SiLencer's .ini but can't find any program with this Header "ProgDVB" because its "ProgDVB ['channelname']".
Is there a away to cut the Header to "ProgDVB" ?
Thx
Aliter
Thx
Aliter
