Hey everyone i bought a liscnese so that i can set up dvr features to record channels at specific times, The schedular itself is working but it is not recording properly. The file is the correct size ( 2 gigs for an hour) but only has 11 minutes worth of recorded data. This happens with any recording i do, i know the streams are fine because recording through PLex dvr is working without an issue.
Also my Progtv for the same links have no audio in dvb and do not play at all in tv mode
EDIT: Audio Fixed
Re: Recording Function not working also no audio.
#2TS format for recording? What format of audio? Check record options.
ProgDVB record streams "IS AS". Possible your playback software not support all audio formats. Try for example MPC (Media player classic) or any other popular player.
#3Ok i have TS set for channel and radio. and for codac im using LAV for everything
I did read i could use nvidia codeacs i just do not know how to enable them
