Since the last 3 Versions i have once in a week the following:
Starting ProgDBV and the progress bar underneath the Picture stops in the middle,
Taskmanager says task not responding progdvb,exe and Splashform_2,bmp
I can´t kill it i had to reboot. Strange behavior. Isnt it ?
Re: Task not responding
#4Need restart PC after every ProgDVB start? That mean ProgDVB crash on exit and BDA driver crash after that. Some BDA drivers are crash if application not close it.
Please enable logs and send me after next case.
