Крэш ПрогДВБ 7.46.02c при нажатии на значок часов справа сверху полоски ОСД.
kostan
kostan
Sun Sep 20, 2009 2:16 am
#1 by kostan
Крэш ПрогДВБ 7.46.02c при нажатии на значок часов справа сверху полоски ОСД. Я уже писал об этом. Так и не исправлен.
TeVii S-460
  • Sat Aug 13, 2022 7:51 am
Re: Крэш ПрогДВБ 7.46.02c при нажатии на значок часов справа сверху полоски ОСД.
Вроде уже была такая тема? Посмотрю.
  • Sat Aug 13, 2022 8:16 am
Return to “Russian”
Re: Two Bugs in v3 portable
I am not can repeat that. Please try last version of ProgTV. Still same?
Prog, Fri Sep 11, 2026 7:30 am
Thanks for report. I am retest that in near time.
Prog, Thu Sep 03, 2026 7:39 am
Hi there. I thought the portable had sorted out a bug I found in the windows app version, but sadly not. It seems that i
fredphoesh, Wed Sep 02, 2026 8:18 pm
Re: ProgTV3 portable
edit
fredphoesh, Wed Sep 02, 2026 7:46 pm
  • It is currently Mon Sep 14, 2026 4:03 pm
