the problem just with the new versions of ProgDVB >>>
I tried 5.03.08 ... making manual command " any command " but do nothing ... the time is correct
just run with commands added by EPG ( For record )
with ver. 4.77.2 it's ok
SS2,XP SP2
Same problem with 5.09 SE, but the run doesnt start at scheduled time defined by epg, only the run button immediatly select the channel list, but no more action (select channel, start/stop record)
In fact unuseable in scheduled programming.
4.85.1 is working well.
