Hi,
I use version 2.77.4 with all options. I have been able to setup the record folder (options, record) in the past. However I have changed the USB stick and I need to reset the recording path, but it doesnt allow me to do that it currently says : VIDEO::808f-9817 which was the identification from the old USB stick. When I select it , it gives a noise (plong) but it does not open any selection window or keyboard setting. All in all, I cant change the record path and cant record now.
The drive is recognised in the app x-plore where it is called : /storage/623E-304B
regards[
Re: setting of recording path
#2Have you tried renaming your new drive to : /storage/623E-304B in your file explorer? or you try doing on a PC. If that does not work try clearing the cache in progtv or better still re install progtv. It might work!
#3Usual app have less rights then file explorer and can access only for some fixed folders. Like video or downloads.
