I have a dish with two LNBs (ASTRA , HOTBIRD)
Both of them works with DiSeqC 1.6 switch.
If I connect the cable to receiver, I can put LNB1 to option A
and LNB2 to option B.
I can receive both of this satellites.
ProgDVB
I have get Cinergy S - USB (my terratec card) as driver in driver list and start it.
After this I put in DiSeqC dialog option (1.0 2.0) and put
Astra to the first tree node
Hotbird to the second tree node.
Searching for new channels there are only Astra channels found.
It does not depend if I get Astra or Hotbird as list option.
Why ?
How to check if the ProgDVB configuration correct is?
Is there any plug-in or other possibility to switch between LNB1 and LNB2 ?
I use the last version of ProgDVB 4, downloaded from the original homepage.
Many thanks for any solution.
Jupiter
